Cisco 3560 & ADSL Line can work?
Jul 27th, 2008
HI, I would like to get expert consult whether ADSL line (do not have fix IP)can work together 3560 (as L3 routing) to establish an office LAN with few difference Vlan?
Currently my physical connection is
Phone line->ADSL modem->ADSL Router-> Cisco 3560-> PC
Edison Ortiz Sun, 07/27/2008 - 19:21
The ADSL is terminated in the ADSL router so the switch should serve its function as a L3 device hosting multiple Vlans on that office.
Wlewx11@@ Sun, 07/27/2008 - 23:31
fyi, the router i m used is LinkSys broadband Router. ADSL modem is Aztech modem
i do have 2 unit of 3560 (both Fa0/1 as L2 route), fa0/2 has change to L3 and ip is
Results of show ip route is subnetted, 1 subnets
C is directly connected, Loopback0
R [120/1] via, 00:00:23, FastEthernet0/1 is subnetted, 1 subnets
C is directly connected, FastEthernet0/1 is variably subnetted, 6 subnets, 2 masks
C is directly connected, Vlan10
C is directly connected, Vlan100
C is directly connected, Vlan48
C is directly connected, Vlan64
C is directly connected, Vlan80
C is directly connected, Vlan96
C is directly connected, FastEthernet0/2
interface Loopback0
ip address 70.x.x.70
interface FastEthernet0/1
no switchport
ip address 141.x.x.9
ip rip authentication key-chain kal
no ip split-horizon
interface FastEthernet0/2
description ISP
no switchport
ip address
