security problems or how to enable telnet and http access
gluckboymail
Another questin, after getting installed of new SDM (2.5) ver, it has changed a security policy. i started setup utility, and this thing told me that HTTP and TELNET are disabled, i tried to enter 'ip http enable' and so on, it doesnt give me an ability to get connected to the terminal via telnet, sdm web configurator also doesnt work, the only way to get connected is to use rs232 interface only. is there a way to turn off that security preset for having an ability to use telnet or http in normal way via ethernet interface? please help me :(
There is access-list 23 which is restricting your access
disable the access-list using the following commands :
no ip http access-class 23
line vty 0 4
no access-class 23 in
Hope this helps.
please post the running-config.
it is in attach
line vty 0 4
Hope this helps.
WOW! Man, I LOVE YOU!! Many thanks!
