configuration file memory full, how to increase
Answered Question
PIX515E showing Not enough memory when saving configuration
flashfs[7]: 10 files, 3 directoriesMessage #36 :
flashfs[7]: 0 orphaned files, 0 orphaned directoriesMessage #37 :
flashfs[7]: Total bytes: 15998976Message #38 :
flashfs[7]: Bytes used: 15998976Message #39 :
flashfs[7]: Bytes available: 0Message #40 :
Please suggest how to increase the size.
Correct Answer by dhananjoy chowdhury about 8 years 5 months ago
Either do "show flash" or "dir" command
myPIX# dir
Directory of flash:/
9 -rw- 1088 18:26:17 Jun 26 2008 old_running.cfg
10 -rw- 659 18:26:18 Jun 26 2008 admin.cfg
11 -rw- 659 12:25:18 Jul 28 2008 my-adm-conf.cfg
12 -rw- 659 12:25:58 Jul 28 2008 C1.cfg
16128000 bytes total (16118272 bytes free)
Here the third column shows file size in bytes.
Overall Rating: 4.8 (3 ratings)
dhananjoy chowdhury Mon, 07/28/2008 - 01:54
Flash is full
Delete the old config files that you don't require.
Or otherwise run the command
"service compress-config" to compress the config files.
dhananjoy chowdhury Mon, 07/28/2008 - 02:42
Sorry, it is not available on pix...
its only on Cisco router.
So only option left is to delete files :)
Correct Answer
dhananjoy chowdhury Mon, 07/28/2008 - 04:32
myPIX# dir
dphills18 Mon, 08/04/2008 - 11:43
is that command available on the access points, 1200 series.
