Unity - Public Distribution List problem!
Jul 28th, 2008
Hi all,
I have a problem with Unity Public Distribution List: I couldnot Add or Remove subscribers to/from the lists (the radio buttons are disabled).
Could you please explain this and give me some workaround?
hoanghiep
Jaime Valencia Mon, 07/28/2008 - 03:50
  • Cisco Employee,
  • Hall of Fame,
    2011
what account are you using when you login?
also unity version? (please always provide versions)
javalenc
if this helps, please rate
ranpierce Mon, 07/28/2008 - 06:53
  • Silver, 250 points or more
When running Permissions Wizard and Message Store Configuration Wizard you need to check the boxes to allow permissions to create DLs
Randy
hoanghiep Mon, 07/28/2008 - 17:43
Thanks for your responses!
The version is 5.0. I logged in Unity with the administrator account (unityadmin)
I can create PDLs but cannot add users to the lists or remove users from the "All user" list.
regards,
hoanghiep
