NAT problems with tcp/udp
Jul 28th, 2008
Ive got a cisco 877 and have ip source static rules setup for tcp and udp ports 2000-2003 2006, 3001 to an internal server at The cisco 877 replaced a draytek vigor which had no problems. Perhaps its the way the ports are defined. Is there anyway I can translate tcp port 2000 and udp port 2000 using one ip nat inside source static rule. I think that could be the reason why things arent working properly
