Frame Relay switch
Jul 28th, 2008
Hi guys, about to tackle ICND2 and want to set up my lab so it can run frame relay. What equipment do I need to do this? Is it simply a router with enough serial interfaces to accommodate either a few routers in multipoint or point-to-point config and is there a specific way I need to configure the router that is the frame switch?
Dean
senthuran Mon, 07/28/2008 - 03:01
Yes,you can configure cisco router as frame-relay switch.enable
(config)#frame-relay switching command.
do a google search for the test configs.
Best of luck for your ICND.
-senthuran
