Database integrity check
Jul 28th, 2008
Actually, I'm experiencing some weird behaviour from my CCM servers. I'm running 4.1(3)SR6 and when I try to add new servers to the cluster it fails.
I check the replication using SQL enterprise manager and DBHelper, and everything is green, thta means that the repication is OK, but how could I check the DB itself. I mean does the DB is ok ?
Does somebody know some tools which can check that ?
Thanks for your help, I'm stuck
Rgds
Luc
