Client AW - (-9986) Session to Local Database could not be opened
Answered Question
Hi All,
I have a Server which has a Client AW installed (NGMICMAWC1). For some reason the software is now unable to connect back to either the Primary HDS (NGMICMAWD1) or the Secondary HDS.
The HDS can see the request from the Client AW but the UAW process returns the following error:
11:35:41 dis-uaw Trace: New trace client: Launcher(upcc) on pipe 0x224.
11:35:41 dis-uaw Trace: [client: Launcher(upcc)] Real-time Client cannot connect to database using ServerName: ngmicmawd1, UserName , SqlCode 2.
11:35:41 dis-uaw Trace: [client: Launcher(upcc)] Session to local database could not be opened. Aborting...
11:35:41 dis-uaw Trace: Info: Trace client on pipe 0x224 disconnected.
Last API Error [109]: Unknown status code 109. GetLastError() after FormatMessage() returned 317
I suspect that the issue is authentication. Looking at the Registry Setting within the CLient AW they are:
Key Name: HKEY_LOCAL_MACHINE\SOFTWARE\Cisco Systems, Inc.\ICM\cap1\AW\RealTimeClient\CurrentVersion\LocalDB
Class Name: <NO CLASS>
Last Write Time: 28/07/2008 - 11:34
Value 0
Type: REG_SZ
Data: MSDASQL
Value 1
Type: REG_SZ
Data: sa
Value 2
Type: REG_SZ
Data: MSS Microsoft SQL Server 6.0
Value 3
Type: REG_SZ
Data: cap1_awdb
Value 4
Type: REG_SZ
Data:
Value 5
Type: REG_SZ
Data: ngmicmawd1
Value 6
Type: REG_SZ
Data: ngmicmawd1
The Client AW receives the following error:
Can anybody point me in the right direction?
Thaks
Dan
Correct Answer by CT.Anderson about 8 years 11 months ago
I ran into this and fixed it by changing the client configuration of the ODBC connection to named pipes. It was set to TCP/P
Overall Rating: 5 (1 ratings)
Hi irisrios,
Thank you for the guide.
I'm running a Enterprise ICM but went through the guide anyways.
I can confirm that under my Cust OU I already have both the LOGGERA.... and LOGGERB doamin accounts which are already included within the SERVICE group...
Any more thoughts?
I'm strugglying to see the link for the account that my Client AW uses to log into the HDS (I'd guess that it uses the account the the users logged onto the box with? If so does this mean that all the users accounts need to be part of the SERVICE group?)
Dan
Hi Geoff,
Correct - All the servers are within the same ICM Domain and I am using a Domain Admin account to login with.
When I open Script Editor I get a slightly different Error:
Error trying to open the database connection to initalize the security system.
The following database errors were retirned:
Database error reading the user ReadOnly flag.
Session to local database couldn't be opened
Dan
Correct Answer
CT.Anderson Mon, 08/18/2008 - 11:22
samuel.barnhouse Mon, 08/18/2008 - 19:29
Try adding the domain accounts to the User List within Configuration Manager, with Configuration rights, and any Feature Control Sets, if you have them.
