SSL VPN users only conenct on Protocol Encryption RC4 - why?
Jul 28th, 2008
My Clientless SSL VPN users only connect to my ASA on RC4 protocol encryption, is this ok? I want them to connect on AES 256 but they can't.
Actually 3DES-168 seems to work as well.
a.alekseev Mon, 07/28/2008 - 05:17
  • Gold, 750 points or more
by default rc4-sha1 takes precedence
you can modify this behaviour by the command
"ssl encryption aes128-sha1 rc4-sha1 aes256-sha1 3des-sha1"
or use asdm
see the attachment
jamesgonzo Fri, 08/01/2008 - 04:50
I tried that but I only ever conenct at RC4-Sha1, even when I put it at the end.
Why is this please?
Farrukh Haroon Fri, 08/01/2008 - 06:23
  • Red, 2250 points or more
It would depend on your browser, wouldn't it?
Which one are you using?
Also what do you have checked under Tools >> Internet Options >> Advanced (SSL 2.0 / SSL 3.0 ?)
Farrukh
jamesgonzo Fri, 08/01/2008 - 06:42
I'm using IE7, under those options I have SSL 3.0, TSL 1.0 selected.
In the ASDM I have Server SSL verion set to any and Client SSL version set to any.
