ACS Evolution Default Username/Password
Answered Question
Jul 28th, 2008
Hi All,
Would appreciate if any of you can let me know the default Username/Password for ACS Trail version for windows.
Adnan
Correct Answer by dhananjoy chowdhury about 8 years 5 months ago
cool..Please rate the post and let me know if you any more help.
Overall Rating: 5 (1 ratings)
dhananjoy chowdhury Mon, 07/28/2008 - 03:31
By default it doesn't have any username/password. You are proabbly trying to access from another system on LAN.
try to open the url
http://127.0.0.1:2002 on the ACS server console itself, it will automatically login without uname/passwd.
dhananjoy chowdhury Mon, 07/28/2008 - 03:34
After that go to "Administration Control" >> "Add Administrator" ... then "Grant All ".
Now you can login from any other system on the network.
Hope this helps
