Can's access ASDM since configuring the SSL settings in the ASDM
whiteford
I have chnaged a setting for SSL in the ASDM of our ASA 5520 which prevents me accessing the ASDM. I can get onto the CLI, what SSL encryption does the ASDM require?
I've been configuring the ASA for clientless VPN connections, and didn't realise they were connected in this way until now :S
lolayo_19
Hey,
Try changing the port you use to acceess the ASDM with the http server enable command.
http server enable 4443
Then try to access the asdm through this port
http://:4443
See if that works
