Cannot use NM-HDA-4FXS as SCCP devices
Answered Question
Jul 28th, 2008
Hi!
I am trying to use a NM-HDA-4FXS module, installed into a 2811 ISR, as a set of SCCP devices with CUCM 6.1. Unfortunately, in the gateway configuration menu I cannot select neccessary type of module, that is installed into Slot 1. There is only NM-HDV2 and NM-HD's. Although, all manuals are saying, that NM-HDA-4FXS is supported.
Somebody has met such problem?
Correct Answer by espereir about 8 years 7 months ago
Hi Dennis,
You are right and I am sorry about the wrong post, I was checking the 2800 Series data sheet and the NM-HDA-4FXS is supported on the 2811:
http://www.cisco.com/en/US/prod/collateral/routers/ps5854/ps5882/product_data_sheet0900aecd8016fa68_ps5854_Products_Data_Sheet.html
However, the problem here is that the NM-HDA-4FXS module does not supports SCCP:
These are supported:
* VoIP H.323, VoIP session initiation protocol (SIP), and VoIP Media Gateway Control Protocol (MGCP) with Call Agent
* Voice over Frame Relay (VoFR)
* Voice over ATM (VoATM)
* VoATM adaptation layer 5 (VoAAL5)
* Trunked ATM adaptation layer 2 (AAL2)
VoIP H.323 and MGCP with Cisco CallManager are supported.
Here is the link:
http://www.cisco.com/en/US/products/hw/modules/ps2617/products_tech_note09186a0080094aba.shtml
I have tested the 2811 with NM-HDA-4FXS on CUCM 6.1.2 and it is listed there. I was able to register this endpoint by using MGCP.
Hope it helps!
Overall Rating: 3 (1 ratings)
dfokin Mon, 07/28/2008 - 22:30
Hello, Esteban!
Thank you for your reply, but NM-HDA-4FXS IS supported on the 2811 platform. The datasheet, link to which you gave, is regarding EVM-HD module.
Correct Answer
espereir Tue, 07/29/2008 - 08:20
  • Silver, 250 points or more
Hi Dennis,
Here is the link:
Hope it helps!
