Gigabit on ASA 5510
gabriel.gearip
How would one go about setting the 1000Mbps speed to a ASA 5510 with the "security plus" license?
This is what I'm getting on any interface:
fw(config-if)# speed ?
interface mode commands/options:
10 Force 10 Mbps operation
100 Force 100 Mbps operation
auto Enable AUTO speed configuration
Thanks.
Gabi
I thhink you should upgrede to 8.0(3)
I have asa 5510 with security plus license.
Cisco Adaptive Security Appliance Software Version 7.2(3)
ASA5510(config-if)#
ASA5510# conf t
ASA5510(config)# int e0/0
ASA5510(config-if)# spe
ASA5510(config-if)# speed ?
1000 Force 1000 Mbps operation
11 Replies 11
hi,
please post output of the command
"show int ip bri"
with the sec+ license, only interfaces 0 and 1 are gig enabled. the others are only 10/100.
http://www.cisco.com/en/US/products/ps6120/prod_models_comparison.html
... and still I can't set eighter e0/0 or e0/1 to gigabit.
fw(config)# sh int ip bri
Ethernet0/0 xxx.xxx.xxx.xxx YES CONFIG up up
Ethernet0/1 xxx.xxx.xxx.xxx YES CONFIG up up
Ethernet0/2 unassigned YES unset administratively down down
Ethernet0/3 unassigned YES unset administratively down down
Management0/0 unassigned YES unset administratively down down
Beginning with Cisco ASA Software v7.2.3, the ASA 5510 Security Plus license enables 2 10/100/1000 interfaces and 3 10/100 interfaces
What Cisco ASA Software do you have?
Yes, I know about that, thank you.
I have version 8.0(2), Security Plus license.
Do any of you know how this works - it's set automatically to 1Gbps or do you need to set it.
Thanks.
ASA5510(config-if)#
ASA5510# conf t
Is this a known bug?
Given that I have a version higher that 7.2(3) I should have this option too...
Its not a 'bug'. Cisco maintains multiple versions at once 7.0.x 7.2.x 8.0.x etc. So it doesnt mean 7.2(3) is older than 8.0(2).
Farrukh
I've upgraded to 8.0(4). Now it works although there is no mention in the release notes about this.
Thanks!
Gabi
Thanks for the update and I'm glad you have it working now :).
But I just checked the release notes and its mentioned there albeit in a slightly covert manner :)
CSCsl53995
5510 interface can be set to1000Mbps with base license
Farrukh
