Users in Presence
Jul 28th, 2008
Hi all. I am trying to play around with Presence in getting it ready for use. Im wondering, in order to see other users, do the users in CUCM have to be application users or just phone users for the Presence client to see the other users?
Overall Rating: 4 (2 ratings)
Ayodeji oladipo... Mon, 07/28/2008 - 05:49
The users in presence are ordinary users. As long as presence is integrated with an LDAP server, they should be able to see them.
Ayodeji oladipo... Mon, 07/28/2008 - 08:12
No! With presence you will need an external LDAP server either AD or others...
You cant use Callmanager LDAP.
jjoseph01 Mon, 07/28/2008 - 12:13
Hey again, one more question on this if you dont mind, when I integrate CUCM and Presence with LDAP, will I also need to do Unity Connection 2.x as well with LDAP integration, or will I just import the new users in from CUCM?
Tommer Catlin Mon, 07/28/2008 - 13:24
You can leave CUCM the way that it is as a stand alone directory. It would be advisable to move to LDAP and CUCM to simplify your administration though. If you integrate CUCM with LDAP, it will sync your LDAP directory to the CUCM. Then you can simply import to CUCM, authentication will be through your LDAP, etc. In CUPS, you will still need to point to an LDAP server. Authentication and user activation will take place *through* CUCM.
make sense?
