CDR data
Jul 28th, 2008
we currently are running ccm 5.1(2b) and was wondering if there is a way to have cdr's written to a mssql database. I can see in CDR Manager where you can setup a Billing Application Server, but that looks like it rights to a flat file. If anyone is doing this or could help shed some light I would greatly appreaciated it.
Overall Rating: 5 (1 ratings)
espereir Mon, 07/28/2008 - 16:13
Hello Jeff,
Linux CCM only writes the CDRs on flat files and can upload them into a (s)FTP application. you will need to write some code in order to insert them into SQL since the CDR 3rd-party integration that we used to have on 4.X/3.X is not longer supported here.
By the way, I have seen that some 3rd-party companies that have developed CDR Billing application servers that converts from flat files into MSSQL records.
Hope this helps!
Jeff Thompson Tue, 07/29/2008 - 06:44
Yes that does help. It confirms what I was finding on my research. Thank you for the response.
