MGCP and H323 Protocols on Same Gateway
Answered Question
Jul 28th, 2008
Dear Folks,
Can we enable both MGCP and H323 on same gateway.meaning that MGCP will use for PRi and H323 for analog Ports.
Also Please give any stable IOS for MGCP.
Thanks in Advance
Correct Answer by Jaime Valencia about 8 years 5 months ago
yes, you can use both protocols on the same GW, this has been asked twice over the past 2 weeks, please try searching on previous posts
javalenc
if this helps, please rate
Overall Rating: 5 (1 ratings)
Correct Answer
Jaime Valencia Mon, 07/28/2008 - 06:10
javalenc
matthubach Tue, 04/08/2014 - 08:56
Possible/Advisable to share the same circuit between MGCP/H323 protocols on the same gateway?
Jaime Valencia Tue, 04/08/2014 - 11:04
Not possible, you need to choose one and stick to it per circuit.
ie 0/0/0 MGCP
0/0/1 H323
