Controller questions
Answered Question
Jul 28th, 2008
We have a 4402 controller and a WiSM module in our core 6513 switch.
Out of the box our 1131 APs always join the second controller on the WiSM. Is there a means to control which controller it the AP joins out of the box? I do not have any of the controllers set as master. I manually adjust the primary and secondary after the AP is up and running. Was wondering what the tertiary field is for.
All our controllers run the same WLANs. Should I be looking at using mobility groups? I need to read up on that a bit. Do controllers in a group share WLAN information such as a change or addition of a WLAN get pushed to other controllers in the group.
Craig
Correct Answer by slapham about 8 years 8 months ago
I have installed 462 of the 1131 Ap's in our environment, and here is the best way I have found.
With the number of Ap's I am using Layer3 with a DHCP server with a scope for each subnet with option 43 giving the AP's all of the controllers addresses(they need to know all for failover purposes). I actually set one controller as Master (just for the config then I turn off the Master). That way I can monitor a single controller and as AP's come up, I can configure the preferred controllers...Tertiary is just for additional redundancy as a Third prefered Controller.
Mobility Groups: This is really used for active information sharing, not configuration sharing. There is a way to mass configure all controllers through WCS using Templates and applying them to all applicable controllers. I hope this info helps...
Overall Rating: 5 (1 ratings)
Correct Answer
slapham Wed, 07/30/2008 - 21:43
Trending Topics - Security & Network
