CTMjrmServer service not starting
Answered Question
Jul 28th, 2008
  • Gold, 750 points or more
For some reason I can't use most functions in ciscoworks due to the JRM service not running. I have manually tried to get get it started and it won't start. It also says that the administrator has shut down this service. Here are a couple of screen shots. Please let me know how I can get this corrected. LMS version 2.6 Common services 3.0.5
Mark
Correct Answer by Joe Clarke about 8 years 11 months ago
Yes, try this. It looks like your System Identity User might be be properly configured in ACS which is affecting JRM.
Overall Rating: 5 (1 ratings)
Joe Clarke Mon, 07/28/2008 - 07:35
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Was the hostname changed on this server recently? Is this server integrated with ACS?
Mark Yeates Mon, 07/28/2008 - 07:38
Joe,
The hostname was not changed but a recently "attempted" integration with ACS server did occur. If that is the culprit I can remove the AAA logon until I get that resolved.
Mark
Correct Answer
Joe Clarke Mon, 07/28/2008 - 07:42
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Mark Yeates Mon, 07/28/2008 - 07:51
I will take out the AAA administration until I can work with the ACS administrator to get that issue resolved. Thanks for your help Joe!
Mark
