Input Drops on TenGigabitEthernet Links
Jul 28th, 2008
I'm seeing input drops/flushes on a group of 10GB interfaces.
Utilization is around 1%, so utilization is not an issue.
What else should I be looking at to determine the root cause?
Overall Rating: 3 (3 ratings)
lamav Mon, 07/28/2008 - 08:17
Just do the obvious first...
Check the fiber cables -- swap them out if you have to
Swap out the GBICs too
Make sure your speed and duplex settings are correct.
You know...basic layer 1 stuff.
Giuseppe Larosa Mon, 07/28/2008 - 09:07
Hello Joseph,
have a look at the following it describes some bugs that might apply to your case
meaning of input drops:
Input queue - The number of packets in the input queue. Size/max/drops means the current number of frames in the queue/the max number of frames the queue can hold before it must start dropping frames/the actual number of frames dropped because the max queue size was exceeded. The input queue size can be modified by issuing the hold-queue in interface command. Be careful when increasing the size of the queue as this may result in traffic delays because the frames get stuck in the queue for a longer period of time.
Hope to help
jrabener Mon, 07/28/2008 - 10:30
Thanks to all for your observations and suggestions. They will help me formulate a strategy to address this issue.
