Anyconnect issue
Jul 28th, 2008
I try to make a tunnel to an ASA device with Anyconnect.
When I start client from PC all is ok regarding contacting the secure gateway, authentication, but after that any time is made an update check and every time is starting the installation of Anyconnect on PC even I have installed the same package like image from the secure gateway. Any ideea?
mherald Mon, 07/28/2008 - 18:03
On any of the SSL group policies, both default and one (or more) that you may have made, under group policies / more options / login settings, under default post login selection, is "download client" checked?
Mike
Valeriu Filipescu Tue, 07/29/2008 - 00:03
Thanks for your answer.
I have checked this download client.
But now I uncheck this and I don't have any improve, client after authentication start a check for update and again reinstall application.
Valeriu Filipescu Tue, 07/29/2008 - 11:36
After removing of this command:
svc modules value vpngina
I resolve my issue. Now I don't have any problem in connect with Anyconnect to my network through secure gateway.(ASA 8.03 - AnyConnect 2.2.0133)
