713042 log
Jul 28th, 2008
Error Message   %ASA-3-713042: IKE Initiator unable to find policy: Intf interface_number, Src: source_address, Dst: dest_address
Explanation   This message indicates that the IPsec fast path processed a packet that triggered IKE, but IKE's policy lookup failed. This error could be timing related. The ACLs that triggered IKE might have been deleted before IKE processed the initiation request. This problem will most likely correct itself.
Recommended Action   If the condition persists, check the L2L configuration, paying special attention to the type of ACL associated with crypto maps.
Hi, The site to Site tunel is active but not able to connect with remote network so I checked the logs and found this log. Can anyone suggest what shd i do ??? Thanks
Farrukh Haroon Mon, 07/28/2008 - 11:08
  • Red, 2250 points or more
Can you post debugs/configs?
Farrukh
