07-28-2008 10:18 AM - edited 03-11-2019 06:21 AM
Getting a FLOOD, huge flood of
" reason: MSS exceeded, MSS 1300, data 1360" on Port 25
running Pix 7.0.4 code.
What is up with this? Have seen some of these in the past, but nothing like the 1 to 3 every second. I think someone is trying to run a SMTP exploit on my port 25. I am not getting these on port 80. Also have not had this huge amount of MSS reject in the past.
Suggestions?
07-28-2008 11:13 AM
This is rarely caused by exploits, this usually problems with the TCP settings on the server/client etc. Have a look at:
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_tech_note09186a00804c8b9f.shtml
As you see Cisco has changed the default from 'deny' to 'allow' due to excessive user complaints starting from release 7.2(4)
http://www.cisco.com/en/US/docs/security/asa/asa72/command/reference/ef_72.html#wp1758645
Farrukh
07-28-2008 11:19 AM
Tech note applies to http sites. I am having an issue with port 25 inbound. My quesiton is can I apply the same to port 25 to bypass the MSS messages.
07-28-2008 11:31 AM
Yes why not.
Farrukh
