ACE SSL Rewrite
Jul 28th, 2008
Hi, Gilles.
I am using ACE to terminate https, the backend server needs send http-302 redirect to http, so I would need ssl redirect to change HTTP://server1.com/xx/yy/zz to HTTPS://server1.com/xx/yy/zz.
But it never works, on the client browser side, seems like ACE only retain the URL path, give me only HTTPS://server1.com/.
I am trying to using the following actlist:
action-list type modify http SSL_ZCS_ACTLIST
ssl url rewrite location "zcs2.*"
what I missed? thanks.
Leo
sachinga.hcl Tue, 07/29/2008 - 09:40
  • Silver, 250 points or more
HI Leo ,
Kindly try the following command
action-list type modify http urlrewrite
instead of using
Because Servers are accepting traffic on port 80. When the server sends a redirect
it is not always sent back to the client as https://.
ACE will rewrite the
location field when it sees http://server1.com/xx/yy/zz and will change it to
https://server1.com/xx/yy/zz before encrypting it back to the client.
