issue of "Out-of-Sync"
Jul 28th, 2008
In our company, there are lots of Cisco Catalyst Blade Switches 3030 for Dell. I always found "out-of-sync" report of these switches. When I opened different version, it is only about "ntp clock-period" change. But actually it did not belong to real change, but other switches (like 3750) were not found the similar report(Even though I could found the same "change").Is this kind of switch bug or is the issue from my settings?
Thanks for your response
Overall Rating: 5 (3 ratings)
Joe Clarke Mon, 07/28/2008 - 12:19
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
These switches must be missing the list of default exclude commands. Go to RME > Admin > Config Mgmt > Exclude Commands, find this switch type, and add the following as the default list:
end,exec-timeout,length,width,certificate,ntp clock-period
