VPN Connected but cannot ping to Cisco Eagle server! HELP
Jul 28th, 2008
I am doing some testing with the cisco eagle server application but cannot access it for some reason... Here is the problem, my VPN client is connected through Interface 0/0 and the eagle server is connected through Interface 0/1 on a 2800 ISR router... I can ping the interface router 0/1 but cannot ping the eagle server that is located on that side of the router... But when I disconnet VPN Client then I can ping it.. I think it has something to do with my ACL list but not for sure.. Could someone give me some words of advice??
Marwan ALshawi Mon, 07/28/2008 - 18:22
do you have NATING
it is nat exmpt issue if you have nating
lets say you VPN pool 192.1681.0/24
and you local network where the server located is
make a nat exmpt as follow
access-list 100 deny ip
access-list 100 permit ip any any
route-map nating permit 10
match ip address 100
ip nat inside source route-map nating interface fa0/0
if you dont have nating at all and you have ACLs on the router interfaces make sure you have given the right access to the VPN client and the retune traffic aswel
good luck
