pca without domain details
Jul 28th, 2008
Hi, does anyone know if its possible while using PCA to login from one domain to another without entering the target domain details, i.e we have a standalone domain, can a customer login without entering the domain details(they dont want to remember 2 domains - even no password would suffice)?...cheers,Jag
Overall Rating: 3 (1 ratings)
aghaznavi Fri, 08/01/2008 - 07:46
I think for each domain we need separate user name and pwd. If the user account is not part of the Domain Admin group, you must add it and reset the password in Active Directory (AD).
Tommer Catlin Fri, 08/01/2008 - 08:53
You can, just have to adjust the IIS settings for that website. You can fill out the domain name in the authentication in IIS for that website and it should work for you. (if I remember right)
askq2forum Tue, 08/05/2008 - 10:29
hi, can you specifically point me as to where the changes are made...Jag
