Two remote sites can not talk to each other
Jul 28th, 2008
Hi friends,
Two VPN tunnels connect two remote sites to head office, both of them are working fine. But the two remote sites can not talk to each other, any ideas or solutions for this? Thanks.
Here are the equipments and version:
Head office: PIX515E 6.3
Remote site1: PIX501 6.3
Remote site2: Router 2800 12.4
Overall Rating: 2 (1 ratings)
xzjleo2005 Mon, 07/28/2008 - 20:13
Looks like it can not be done on 6.3 version. Anyway, thanks for your reply.
Marwan ALshawi Mon, 07/28/2008 - 20:43
it should be possiable
also there is an other way to achive it
by useing easy vpn client and server
make both spokes as clients with RRI and the hub as server
by the way you need to issue the following command to allow the comunication between spokes through the hub
same-security-traffic intra-interface
command in the global configuration mode
xzjleo2005 Mon, 07/28/2008 - 20:47
The version on my PIX is 6.3 which does not support the commands you mentioned. So maybe I need to upgrade to 7.x
