jsivulka Fri, 08/01/2008 - 07:46
  • Bronze, 100 points or more
You can use DHCP option 33 on 3750 IOS to push a static route for a subnet.
Option 33 will allow you to insert static routes on your DHCP configuration but it will only accept classful networks and it limited to allow only two networks. The way to configure this is:
config t
ip dhcp pool
option 33 ip 172.16.0.0 172.18.18.1 172.17.0.0 172.18.18.1
I hope you find this information useful.
xiaoliangyue Fri, 08/01/2008 - 08:43
Hi, Joseph,
I tried option 33 before. However, the route on my Win XP machine looks like this:
172.16.0.0 mask 255.255.255.255 172.18.18.1
not usable at all.
If IOS propagates a host route to client, it's fine.
Thanks anyway.
Jonathan
