Router & ASA connected with Private IP for Internet Access
Jul 28th, 2008
Internet link is terminated into router with public ip.
Router & firewall connected with private ip.
DMZ is having 2 ip segments that are being accessed from inside & outside zone.
LAN zone:
WAN: 212.x.y.z
Can someone help me with config script of both router & firewall
Overall Rating: 4 (2 ratings)
dhananjoy chowdhury Mon, 07/28/2008 - 23:18
On the router suppose you have
S0/0 - 212.x.y.z - Internet
f0/0 - - Inside connecting to ASA outside interface
then configure this way on the router -
int s0/0
ip add 212.x.y.z
ip nat outside
int f0/0
ip add
ip nat outside
access-list 10 permit
ip nat inside source list 10 interface serial 0 overload
-- Also add routes for and on the router, pointing towards ASA outside interface IP.
Now on the ASA, configure the interfaces and then add default route pointing towards the router f0/0 IP (
route outside 0 0
Hope this helps.
acharyr123 Mon, 07/28/2008 - 23:28
I think int f/0--> ip nat this right??
i do have another thought in my mind:
suppose all natting is being taken care by pix, whether only a default route towards isp & static routes pointing inward towards dmz zone will wotk!!!
dhananjoy chowdhury Tue, 07/29/2008 - 01:01
int f/0--> ip nat inside
yes this is correct because you are going to nat all inside subnets behind f0/0.
acharyr123 Mon, 07/28/2008 - 23:32
i also have a query: in that case whether no natting is required into the firewall?
acharyr123 Tue, 07/29/2008 - 01:48
all natting is already been taken care by asa as it is running. router will be installed now so i don't want to change asa configuration.
can this be done!!!
dattx_fis2 Tue, 07/29/2008 - 02:19
NAT for internet access is done on the router. If you want to hide the DMZ ip add, in this case NAT is done on the ASA
acharyr123 Tue, 07/29/2008 - 11:13
I want to have internet link terminated into router & dmz server zone at pix. as pix is already running so don't want to chanhe the config of the same.
Can someone help me with the config!!
Marwan ALshawi Tue, 07/29/2008 - 18:43
ok make PATing over your public ip on the router for all your internall networks
access-list 100 pemirt ip any any
route-map pating permit 10
match ip address 100
ip nat inside source route-map pating inteface (ur outside interface
then on ur inside router interface
ip nat inside
and on the outside interface
ip nat outside
regarding that you have the proper ACLs,NATing and default route on your PIX
also you should have the roight default route configured on your router
good luck
please, Rate if helpful
acharyr123 Tue, 07/29/2008 - 22:03
In PIX i configured the default route towards router inside interface & inside routes towards my lan segment.
global (outside) 1 inetrface outside
global (intf2) 1 ---> intf2: dmz1
global (intf3) 1 ---> intf3: dmz2
nat (inside) 1
ip nat inside source route-map pating inteface fe0/1
int fe0/0
ip nat inside
int fe0/1
ip nat outside
ip route fe0/1
please check if it is ok. then i will try & update you.
Marwan ALshawi Tue, 07/29/2008 - 22:20
what i sugesst you to do is remove the above nating
and make static nat on your pix for the whole submet i mean you give exposior to the whole inside and dmz subnet to the router and on the router do the NATING as i told you
do the following on the PIx
static(inside, outside) netmask
the above command does not actually translate inside addresses so that the router can communicat and see the directly
by the way i assumed that the subnet mask is put it is you have it in your network
then do the same for the dmz network
static(intf2,outside) netmask
again put the subnet mask as you have in your network
and then do the PATING as i told you in the prevous post
ip nat inside source route-map pating inteface (ur outside interface) overload
(dont forget the overload)
ip nat inside
ip nat outside
it shoul work
and use your ACLs to control what allwoed from outside to inside or dmz
by the way
you can use the same concept between the inside and the dmz
good luck
Marwan ALshawi Tue, 07/29/2008 - 23:58
by the way
when you gonna do the configuration i have mentioned on ur PIX
dont forget to remove all the nat config that u have first then do the config i told u about it
about the router
try to put the work overload after the
ip nat inside source route-map pating inteface fe0/1 overload
also what kind of connection with internet u have ?
ADSL or what ?
acharyr123 Wed, 08/06/2008 - 02:43
I tried as per ur config but not working. Pleae find the config & try to help me out in this.
inteface f0/0 overload
interface FastEthernet0/1
ip address
ip nat inside
interface FastEthernet0/0
ip address 116.x.x.x/28
ip nat outside
ip route 116.x.x.y
route outside
route inside
access-list 110 extended permit icmp any any
access-list 110 extended permit ip any any
access-list 110 extended permit tcp any any
access-group 110 in interface inside
static (inside,outside) netmask
Plz suggest
Marwan ALshawi Wed, 08/06/2008 - 02:55
what is the problem with that config
u mean u cant go from the firewall to the outside??
by the way is the network connected directly to ur inside firewall interface?
what is this command????
route inside
please discribe it
i think here we have a leak
acharyr123 Wed, 08/06/2008 - 02:59
With this config, from router i can ping any public ip but from firewall pinging outside ip is not happening. From firewall inside ip & vlan is pinging.
interface GigabitEthernet0/1
nameif inside
security-level 100
ip address
route inside (> inside vlan interface ip )
Marwan ALshawi Wed, 08/06/2008 - 03:13
first u dont need this command
route inside
and if u pinging from inside to the router outside
then the config i have sent u is working!!
and for ur knowledge
in ASA firewall u cant ping an interface from another interface
please, if helpful rate
Marwan ALshawi Wed, 08/06/2008 - 03:35
did u get it work?
dont forget the interface subnet mask should be
als all ur hosts in that inside network
should be in subnet
as we configured the nating with
and let me know
good luck
acharyr123 Wed, 08/06/2008 - 03:39
my inside network is not /8, i have /24,/25 etc. what u suggest in that case!!
acharyr123 Wed, 08/06/2008 - 04:02
Please find the attachment for asa config..router config u alredy have.
There are approx 210 no'f vlans into dist switches (4507R) which bare connected with 6513.
ASA is connected directly with Core switch.
In core vlan 900
ip address :
asa is connected to this vlan.
Marwan ALshawi Wed, 08/06/2008 - 04:33
ok then keep ur config as it is
and do the static nat as i told u befor
enable icmp inspection for ping:
policy-map global_policy
class inspection_default
inspect icmp
inspect icmp error
also do the following to let the firewall do ping its self
permit icmp any interface outside echo
permit icmp any interface outside echo-reply
by the way the config u sent me withiut any nating configured?
so sure when u do show xlate will give u 0
and one more question when u done my config have u get ur inside network working normaly i mean cna go out the router and ping ?
check u r network behind the switch if it has the right config and right defuale gateways conffigured
and let me know
it should work just do it care fully and step by step
good luck
acharyr123 Wed, 08/06/2008 - 06:04
My LAN is working fine. I can ping asa inside interface, i am not able to ping asa outside or rouetr laninterface.
Marwan ALshawi Wed, 08/06/2008 - 06:24
do u have route to ur inside network on ur router?
i mean for
u need to have on ur router somthing like:
ip route [asa ouside ip]
also for icmp
have u don on ur asa:
permit icmp any inside echo
permit icmp any outside echo
and i told u cant ping the asa outside interface from inside or dmz
in other words u cant ping any asa interface from other interface
just u need to get the ping to the router
please after u finish all the config post them to me if didnt work
with full config
acharyr123 Wed, 08/06/2008 - 20:43
i will do this & let you know. Bye the way..thank u very much for your help.
acharyr123 Fri, 08/08/2008 - 01:44
It's working..thanx a lot.
but access is happening only from 10.20.x.x/16. i did this into asa:
My asa inside interface ip: /16.
But i have number of vlans in the range /24,/25,/26 etc with 10.145.x.x series in LAN. from such ddresses internet is not happening.
your suggestion on tjis any !!!
Marwan ALshawi Fri, 08/08/2008 - 01:49
do u have the right vlan and default gateways configured
also route
now it is routing problem
first check the default gateway configuration and make sure they can oping the asa
also make sure u have the route configured through the inside interface on the ASA
please, rate the helpful post
and good luck
acharyr123 Thu, 08/21/2008 - 19:41
I tried to do this ut not happening.
From user side i can ping the asa inside interface. In my switch default route o.o.o.o o.o.o.o 10.20.10.X (asa inside ip) is given.
In switch vlan 900 is created & asa inside is assigned an ip from that segment.
Internet access is happen ing from only vlan 900..from other vlan i can't access internet.
plz suggest.
acharyr123 Wed, 08/27/2008 - 00:19
I am sorry to say that internet is not happening from any of the vlan's.
I have connected my pc directly with the asa inside interface having the pc g/w as inside interface still not happening.
plz help
