07-29-2008 12:32 AM - edited 03-06-2019 12:30 AM
Hi all,
I am experiencing some issues with slavedisks on 2 C6509
Here is the error message :
COR#show slavedisk0:
-#- --length-- -----date/time------ path
number of file 2
inode path is 1 s72033-pk9s-mz.122-18.SXD6.bin
fullpath is disk0://s72033-pk9s-mz.122-18.SXD6.bin
%Error show slavedisk0: (Directory entries are corrupted, please format the disk) COR#
The error remains even if the slavedisk is formated and the file copied again...
Any idea ?
08-04-2008 10:40 AM
The output you are seeing on the show slavedisk0: command is usually indicative of two issues, either the flash card was badly formatted, or the flash card is faulty.
The first troubleshooting step would be to format again the flash card. So proceed to do that using the format command. If after that it continues to fail, change it to disk0: of the active sup and try formatting it.
08-04-2008 10:24 PM
Thanks for you answer. I already try to format the card on one or other sup. Unfortunately, it does not solve the problem.
The card may be faulty, the problem is that I have this problem on 2 differents (relatively new) switches. How can I explain that ?
01-30-2009 12:35 AM
solved. the 2 sup cards where not in same IOS version. (SSO mode configured, RPR mode active)
