07-29-2008 12:33 AM - edited 03-15-2019 12:15 PM
Hello.
How can I view inbound calls statistics in CM 4.1?
Thanks in advance.
Daniele
07-29-2008 08:33 AM
not sure what you want to see, you can try RTMT for that
also CAR tool
java
if this helps, please rate
08-12-2008 05:04 AM
Hi, thanks for your reply.
I need to have a complete report with ALL calls, inbound or outbound.
For example:
12/08/2008 15:34 number 1234 calls number 0123456 duration 5 minutes
08-12-2008 07:15 AM
OK, answer is still the same
use CAR
java
