Error in AP1250
Jul 29th, 2008
I have installed an AP 1250 , i would like to check whether the device will support 802.11 A ,G Series Adapter
slapham Wed, 07/30/2008 - 20:40
When you say 802.11 A,G Adapter, or you saying for the client? What kind of error are you getting?
ignatiusrajkumar Wed, 07/30/2008 - 21:06
The error I have faced after installation of AP 1250 was releated to the Client adapter.
My doubt whether my client adapter which is in 802.11 a /b/g will support AP 1250 which is in 802.11 n.
slapham Wed, 07/30/2008 - 21:13
Would the client not associate to the AP? Does the AP see the client trying to associate? In a nutshell, 802.11n just aggregates multiple a or g radios. The 802.11n is also an a/b/g radio. If this is a new install, I would check to make sure you have enabled the radios as the radios are disabled from the factory. I hope this helps...
ignatiusrajkumar Sat, 08/02/2008 - 02:59
Hi Slapham,
Thanks for your feedback,there was a problem
at the Client Interface and hence the association did not take place with the AP the same was taken care, Thanks for your support.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
