07-29-2008 02:36 AM - edited 03-15-2019 12:15 PM
hi I have two callmanager express systems but only one unity express. Can the other ccme without CUE use the CUE on the other system?
regards
Colin
07-29-2008 02:49 AM
I am sorry but Cisco UE can provide voice mail to only a single Cisco CME site. You cannot "centralize" one Cisco UE system to provide voice mail to multiple remote Cisco CME sites, as you can do with a Cisco Unity system.
HTH, pls rate useful posts
07-29-2008 04:20 AM
Hi Colin/Deji
Just thought I should throw this into the mix. I believe this restriction has been lifted with CUE 3.2;
Deji, you are correct on the CUE references. Here is the "old" info;
Cisco Unity Express must be installed on each Cisco CME host router. Cisco Unity Express cannot provide voice-mail services across Cisco CME routers.
Here is the new info (I don't think CUE 3.2 is out quite yet - but soon I hope);
Q. What are the new features introduced with Cisco Unity Express 3.2?
A. Cisco Unity Express 3.2 introduces the following enhancements:
⢠Integration with multiple Cisco Unified Communications Manager Express sites: Cisco Unity Express (on NME-CUE only) can integrate with up to 10 Cisco Unified Communications Manager Express remote sites. This solution allows centralized voicemail and Automated-Attendant features for up to 10 sites when voicemail at each remote site branch is not essential and there is a small number of users at each site.
Q. Which releases of Cisco Unified Communications Manager Express will be supported with Cisco Unity Express Release 3.2?
A. Cisco Unity Express **will be supported with Cisco Unified Communications Manager Express Releases 4.0, 4.1, 4.2, and 4.3.
Cisco Unity Express Release Notes
http://www.cisco.com/en/US/products/sw/voicesw/ps5520/prod_release_notes_list.html
Hope this helps!
Rob
