QOS configuration error
Jul 29th, 2008
Presently I am using the below IOS in my 7600 router
c7600rsp72043-advipservicesk9-mz.122-33.SRC1.bin
In qos configuration i am getting the following error
------class-map match-all ILL
match access-group name ILL
class-map match-all UNCAP
match access-group name test5
policy-map Child
class UNCAP
police 10000
policy-map Parent
class ILL
service-policy Child
HFCL-GW-2#
HFCL-GW-2#conf terminal
Enter configuration commands, one per line. End with CNTL/Z.
HFCL-GW-2(config)#
HFCL-GW-2(config)#
HFCL-GW-2(config)#int gigabitEthernet 1/9
HFCL-GW-2(config-if)#service-policy input Parent
Hierarchical policymap is not supported for this interface. Configuration failed
rajib_das Tue, 07/29/2008 - 05:03
Hierarchical policymap is not supported in Cisco
7600 router with image c7600rsp72043-advipservicesk9-mz.122-33.SRC1.bin
regards
Rajib
a.rooprao Tue, 07/29/2008 - 05:27
pl let me know the ios name where it can suooprt
supporting data sheet also
a.rooprao Tue, 07/29/2008 - 21:44
Can any one help me on this
Pl can you share any doc on this
Joseph W. Doherty Thu, 07/31/2008 - 08:55
6500/7600 QoS support for LAN interfaces is often not as extensive as the support for some WAN interfaces or what the "software" routers support. However, with what you're trying, you might need a shaper within the parent's class (unsure though). E.g.
policy-map Parent
class ILL
shaper average ####
Again, unsure whether the above will help, but you might try it.
Also, from what you're posted, something like:
class-map match-all ILL_n_UNCAP
policy-map SinglePolicy
class ILL_n_UNCAP
police 10000
Might work.
