site-to-site vpn
Jul 29th, 2008
Hi, I can't get my site-to-site vpn to work. When I try to generate traffic from one internal host another. The trafic never arrives.
Traffic flow:
192.168.100.12 -> 192.168.100.1 -> 213.136.41.180 -> internet -> 79.136.112.50 -> 192.168.1.5
If the ipadresses on the other side of my tunnel are private 192.168.x.x, I need to add a route to outside ip address of that firewall right?
For example: route outside 192.168.100.0 255.255.255.0 213.136.41.180 1
One of my 5505:
access-list l2l_list extended permit ip 192.168.1.0 255.255.255.0 192.168.100.0 255.255.255.0
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0
nat (dmz) 1 0.0.0.0 0.0.0.0
static (dmz,outside) tcp interface ftp 192.168.200.2 ftp netmask 255.255.255.255
static (dmz,outside) tcp interface 8080 192.168.200.2 8080 netmask 255.255.255.255
static (dmz,outside) tcp interface www 192.168.200.2 www netmask 255.255.255.255
access-group 8080_access_in in interface outside
access-group dmz_access_in in interface dmz
route outside 0.0.0.0 0.0.0.0 79.136.112.49 1
crypto ipsec transform-set FirstSet esp-3des esp-md5-hmac
crypto map abcmap 1 match address l2l_list
crypto map abcmap 1 set peer 213.136.41.180
crypto map abcmap 1 set transform-set FirstSet
crypto map abcmap interface outside
crypto isakmp enable outside
crypto isakmp policy 1
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 43200
tunnel-group 213.136.41.180 type ipsec-l2l
tunnel-group 213.136.41.180 ipsec-attributes
pre-shared-key *
The Other one:
access-list l2l_list extended permit ip 192.168.100.0 255.255.255.0 192.168.1.0 255.255.255.0
access-group outside_access_in in interface outside
route outside 0.0.0.0 0.0.0.0 213.136.41.182 1
route outside 192.168.1.0 255.255.255.0 79.136.112.50 1
crypto map abcmap 1 set peer 79.136.112.50
encryption 3des
hash sha
group 2
lifetime 43200
tunnel-group 79.136.112.50 type ipsec-l2l
tunnel-group 79.136.112.50 ipsec-attributes
pre-shared-key *
Overall Rating: 5 (1 ratings)
acomiskey Tue, 07/29/2008 - 05:37
"If the ipadresses on the other side of my tunnel are private 192.168.x.x, I need to add a route to outside ip address of that firewall right?"
-NO
Add nat exemption to the ASA's.
First ASA-
access-list inside_nat0_outbound extended permit ip 192.168.1.0 255.255.255.0 192.168.100.0 255.255.255.0
nat (inside) 0 access-list inside_nat0_outbound
Second ASA-
access-list inside_nat0_outbound extended permit ip 192.168.100.0 255.255.255.0 192.168.1.0 255.255.255.0
