07-29-2008 07:07 AM - edited 03-18-2019 09:23 PM
I attempted to update my CUE to 3.2.1 but it failed while downloading the language package. Now tf fails to boot with the following
Welcome to Cisco Service Engine
Mon Apr 21 07:53:00 EDT 2008
********** rc.aesop ****************
Populating resource values from /etc/aim_rsrc_file
rsrc_file:/etc/default_rsrc_file
Populating resource values from /etc/default_rsrc_file
rsrc_file:/etc/products/cue/default_rsrc_file
Populating resource values from /etc/products/cue/default_rsrc_file
entry : change cli_server:standalone:int32:0
rsrc_file:/etc/products/cue/aim_rsrc_file
Populating resource values from /etc/products/cue/aim_rsrc_file
lcp: .3 COMPLETED
lcs: .3 STARTED
start_next_phase .3
main sub_phase: 3
nsp phase_file: /bin/installer_phase_steps
It just hangs here. I have attempted to use the boot helper option but the TFTP connection opens and drops a few seconds after that. Is there anything else I can try at this point? Is there another way to get things reset?
Solved! Go to Solution.
07-29-2008 07:30 AM
Try downloading the boot helper to the router flash and TFTP'ing off the router directly. I've seen the CUE have issues with loading the boot helper across the network on occassion.
If you can get the boot helper to load, try the disk cleanup option.
07-29-2008 07:30 AM
07-29-2008 07:38 AM
I tried that but did not have enough space on the flash. I will see if I can get bigger flash. Correct me if I am wrong but I can just format a store bought flash as FAT and copy the existing files over, right?
07-29-2008 10:32 AM
I was able to use a USB drive to put the helper file on and TFTP from there. I was able to reinstall after that. Thanks for letting me know about the TFTP issue.
