Interface POS1/0 on Cisco 7204VXR (NPE-G1) IOS ver.12.4(10a)
Jul 29th, 2008
Good evening I should compare with you about packets loss on interface POS as in subject title, below there's output of #show interface:
c7200-B#sh interface POS1/0
POS1/0 is up, line protocol is up
Hardware is Packet over Sonet
Internet address is 151.5.129.82/30
MTU 4470 bytes, BW 155000 Kbit, DLY 100 usec,
reliability 255/255, txload 50/255, rxload 17/255
Encapsulation HDLC, crc 32, loopback not set
Keepalive set (10 sec)
Scramble enabled
Last input 00:00:00, output never, output hang never
Last clearing of "show interface" counters 1y7w
Input queue: 0/75/408/475721 (size/max/drops/flushes); Total output drops: 6088583
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 10633000 bits/sec, 2351 packets/sec
5 minute output rate 30558000 bits/sec, 4375 packets/sec
38925456046 packets input, 12730571287209 bytes, 6 no buffer
Received 0 broadcasts, 96041 runts, 0 giants, 0 throttles
0 parity
1727419 input errors, 1722585 CRC, 0 frame, 0 overrun, 0 ignored, 830 abort
59506239747 packets output, 48623033650494 bytes, 0 underruns
0 output errors, 0 applique, 10 interface resets
1 carrier transitions
Have you any idea?
At this moment I had ask an analysis over the link at my carrier.
Could you suggest me IOS command to verify that i don't have hw problem on POS interface, or any configuration problem?
Any information that you can send me are welcomed.
Best Regards
Davide Sacca'
vmiller Wed, 07/30/2008 - 14:34
Your counters are over a year old. I would not put much behind these numbers since there is no way to tell when any of this happened. Clear the counters and check in 24 hours to see if the incremented.
