07-29-2008 08:13 AM - edited 03-10-2019 04:00 PM
I'm looking for an easy way to purge 5,000 users from the Cisco ACS database.
Are there any tools that will allow me to script account deletion?
thanks,
matt.
07-29-2008 09:06 PM
you can use the "CSUtil.exe" utility to delete users from command line.
Suppose you want to delete users alpha,beta,zeta
first create a text file suppose del_users.txt , which would look something like this:
OFFLINE
DELETE:alpha
DELETE:beta
DELETE:zeta
Then go to bin directory under the ACS install folder and then execute this
csutil.exe -i del_users.txt
You can also add user "venus" in Group 2 and delete user "samba" with this then use something like this
OFFLINE
ADD:venus:PROFILE:2:CSDB:password123
DELETE:samba
For more options of the CSUtil tool check this link
http://www.cisco.com/univercd/cc/td/doc/product/access/acs_soft/csacs4nt/csnt21/apimport.htm
Hope this helps.
07-31-2008 04:28 AM
thanks for that.
Do you know if there is any way to extract a list of usernames and the 'real name' field from the supplementary info?
If you dump the entire databse it seems to be there but i would need to find some way of extracting that data.
Name = Username
App00 USER_DEFINED_FIELD_0 = Real name
thanks,
Matt
07-31-2008 07:11 AM
Hi Matt,
You extract the username / real name from the dump file using Perl / shell scripts.
Also if you only need the list of usernames with groupnames, then you could use the command
csutil.exe -u
this will dump the usernames with groups in a file "users.txt".
07-31-2008 07:16 AM
Its more just real name and username i require so the group option isnt of much use i'm afraid.
Do you have any sample scripts that will parse that log?
thanks.
