Welcome to the Community!
The Community is a hub for connecting with your peers and Cisco specialists to ask for help, share your expertise, build your network, and grow professionally.
New Here? Click here to learn more and get started.
1928831members
1242676discussions
Community Activity
Configuring NAT overload with vrf lite on a CAT9K
Good day;Need help with how I can configure NAT overload with an existing vrf on a CAT9K_IOSXE V16.12.  This is what I am struggling with, I currently have a vrf called AWSDX-S3.  Now what I am trying to do is I have added a L2 SW and ran trunk ports...
gurowar by Level 1
  • 298 Views
  • 13 replies
9800 WLC-Same Vlans on multiple sites in SD-WAN setup
I have a 9800-CL in an SD-WAN setup. I have multiple sites that have the same Vlans at each site to make it easier to manage and remember.Ex:NorthSite: data-4, voice-5, wifi-6SouthSite: data-4, voice-5, wifi-6etc...My current WLC configuration has on...
GeorgeC71 by Level 1
  • 106 Views
  • 4 replies
Resolved! Dual ISP connection gi0/2 not able to connect to internet
Hello,I need your help - currently we have a  2921 Cisco router connected to dual ISPs using "gi0/0 & gi0/1" and we are able to connect to either ISP successfully.  Once we connect gi0/2 to any device the connected switch is not able to access the in...
dgrant524 by Level 1
  • 80 Views
  • 9 replies
WLC 5508 licenses
I have a WLC with 11 registered access points I tried to integrate a new equipment, but I see that I already have my 37 licenses in use. Can you guide me and let me know what this is due to?there is a way to release licenses from the WEB portal or...
angelalmaras_0-1713897847230.png angelalmaras_1-1713898066080.png angelalmaras_2-1713898103303.png
Client Failed to associate
Hello Team, I get some clients on Guest failing to associate. And this is what I find in Prime events about one of the clients.Can someone help with the explanation for this event and the fix.Also client is supposed to get the EUP page and accept it....
collrbbrt by Level 1
  • 116 Views
  • 6 replies
Resolved! Stop in progress template provisioning
Hello everyone.  I'm very new to DNAC or Catalyst Center.  I've setup a project with a template to add a simple configuration to switches.  It currently has been in progress for 10 days and hasn't made a change to a switch yet.  I'd like to cancel th...
Gricel by Level 1
  • 37 Views
  • 2 replies
Cisco CM Switch Box
Our Forum Alert III Secondary Crash Net (SCN) is inoperable. I've heard the cisco cm could be configured to set up some devices to act as a ringdown, they called it a “Switch Box.” This would allow our Base Operations guys to have a work around from ...
unknown IPs in FTD outbound logs
I am managing FTD-1120s with FMCv both running v7.2.1 software.  In my ACP I have a GEO rule to block all outbound traffic to China, Russia, and I few other "hotspots".   When I search for events that match this rule, most of the traffic is from inte...
tato386 by Level 6
  • 168 Views
  • 6 replies
  • 1 Helpful votes
IP routing using domain
The host for my current server (Windows Hyper-V machine with four or five VMs) that handles my email and web sites is going away. I'm planning on moving that physical server to my house and using DDNS to route that traffic in. Realize this is very lo...
