Upgrade CCM 4.13 to 6.12
We have ONE cluster with 3 CCM4.13 servers and going to upgrade to 6.12 with 3 brand new servers.
Try to read all the doc, but somewhat confuse a little:
I know that I have to run Callmanager upgrade utility and DMA 6.12 and correct all the errors and warnings if there are any at DMA log.
However, I dont know the sequenece how to install CCM6.12
Should I install CCM6.12 as a publisher first, then import DMA? Then install CCM6.12 at the rest of servers as subscriber??
OR
Should I install CCM 6.12 as publisher, then subscriber? And import DMA database at last??
Ken
Overall Rating: 5 (2 ratings)
Ayodeji Okanlawon Tue, 07/29/2008 - 08:44
  • Cisco Designated VIP,
    2017 IP Telephony
You install the publisher first and during oyur install, the system will ask you if you want to import DMA file, chosse yes and then inport the file.
AFter the install completes succesfully,
You can then add your subscribers.
Please note that you will need to configure the subscribers first on the publisher before you can add them to the cluster
HTH, pls rateuseful posts
Ayodeji Okanlawon Tue, 07/29/2008 - 08:55
    2017 IP Telephony
No, you cant use CD...
The DMA Retrieval Mechanism Configuration
used to retrieve the DMA file:
• SFTP-Retrieves the DMA file from a remote server by using Secure File Transfer Protocol
(SFTP). The SFTP server must support the following commands: cd, ls, get.
• FTP-Retrieves the DMA file from a remote server by using File Transfer Protocol (FTP). The FTP
server must support the following commands: cd, bin, dir and get.
• TAPE-Retrieves the DMA file from a locally attached tape drive
Note To support retrieval of the DMA file, an FTP server should support the cd, bin, dir, and get
commands., and an SFTP server should support the cd, ls, and get commands.
