07-29-2008 09:19 AM - edited 03-03-2019 10:56 PM
When should I use "interface Loopback"?
Why it is used on the routers?
07-29-2008 09:27 AM
Brief explanation can be found at:
http://www.ciscotaccc.com/kaidara-advisor/lanswitching/showcase?case=K11397092
07-29-2008 09:36 AM
HI, [Pls RATE if HELPS]
Refer the link below, having the details about the earlier POST that was answered:
PLS RATE if HELPS
Best Regards,
Guru Prasad R
07-29-2008 10:57 AM
Loopback interfaces are virtual interfaces and therefore are not succeptable to hw failure. also I use Loopbacks in OSPF evnironments for router identifier
Ex:
interface loopback0
ip address x.x.x.x. y.y.y.y
router ospf
router-id x.x.x.x. where x.x.x.x is the loopback0 interface created. HTH
07-30-2008 03:49 AM
Ex:
interface loopback0
router ospf
Any body can say some example like this?
07-30-2008 03:59 AM
Hi Alexandr Kulbida,
Loopback interface can be used for OSPF, IPSLA, SNMP TRAP, NTP etc.
More details: http://en.wikipedia.org/wiki/Loopback
Goutam
