3745 router does not accept any key input
Answered Question
I have a 3745 router that boots, displays all the boot information while booting, but after it boots and says "Press Return to get started" it dos not accept any keyboard input.
I wanted to try to boot the router in ROMMON mode to see if the baud rate is mismatched, but I am not able to use "CTRL +Break" to go into rommon.
I have removed all cards from it and it only has CISCO3745-IO-2FE blade.
Correct Answer by Giuseppe Larosa about 8 years 2 months ago
Hello joel,
9600 baud rate
8 bit
1 bit stop
no parity
flow control xon/xoff
verify the cable on another cisco device
have the console before powering up the router
see also
Hope to help
Overall Rating: 5 (1 ratings)
