CUCM 6.1.1 upgrade to 6.1.2
Answered Question
Jul 29th, 2008
I have applied the 6.1.2 upgrade to all servers in the cluster but have not yet switched versions. I wanted to find out if I can make the switch on the fly without interupting service to the customer.
Correct Answer by Jaime Valencia about 8 years 11 months ago
if you do not want to interrupt service do it after hours on a maintenance time
most probably also new firmware will be in the version so if any phone resets they will get the new firmware
java
if this helps, please rate
Overall Rating: 4 (1 ratings)
Correct Answer
Jaime Valencia Tue, 07/29/2008 - 11:47
  • Cisco Employee,
  • Hall of Fame,
    2011
java
zzbronski Tue, 07/29/2008 - 12:00
Thank you. I was told by Presidio that it was a hot swap type of operation with the new 6.x version. I guess that info was incorrect. This post can be resolved
