jalmanza_82 Tue, 07/29/2008 - 12:04
Thanks, mhellman.
How do I know the MARS send the email?
There is any logs for this action?
Where can I find it?
Thanks for the help.
mhellman Tue, 07/29/2008 - 13:35
well, you could start by logging into the MARS CLI as pnadmin. Use tcpdump to monitor the SMTP traffic.
[pnadmin]$ tcpdump -X port 25
Now select the report and click "resubmit". You should see the SMTP traffic to the mail server. You can probably troubleshoot by looking at the ASCII output from tcpdump. If not, look at the tcpdump output and at least make sure the connection is to the right IP address and that some data is exchanged after the initial TCP handshake. Now take a look at the mail server logs, which should give you an idea of what to do next.
