Cannot connect using Cisco VPN client
Answered Question
Jul 29th, 2008
Hi all.I have recently configured an ASA 5510 to allow remote access using Cisco VPN client. The problem is that everything works fine when I connect using a classic modem or over a machine with a public address that I use for testing purposes but whenever I try to connect with over an ADSL line I cannot gain access to the resources. I login and after that nothing, I can't reach anything.
I'm attaching the relevant configuration information in the attachment.All help is most welcome.
Correct Answer by acomiskey about 8 years 9 months ago
Depending on version, add..
isakmp nat-traversal
or
crypto isakmp nat-traversal
Should be all you need.
Overall Rating: 5 (1 ratings)
Correct Answer
acomiskey Tue, 07/29/2008 - 12:14
  • Green, 3000 points or more
or
IgorHamzic Tue, 07/29/2008 - 12:40
Thanks that did it. I can ping and access resources without problem.
