Allowing VPN Client access to internet without split tunneling
Jul 29th, 2008
Hi, I'm trying to setup my pix515E ver. 8.0 to allow access to internet without using split tunnel. I am able to get connected, but unable to do anything else. Any help will be appreciated. I did try the vpn on a stick, but no luck. Also, tried some of the other fixes that worked for others. Config attached.
Thanks in Advance
acomiskey Tue, 07/29/2008 - 12:26
  • Green, 3000 points or more
Is the only problem the vpn on a stick, or the vpn is not working at all?
You don't need the outside access list for the vpn traffic since you most likely have sysopt connection permit-vpn, which is enabled by default.
Hairpinning configuration looks ok.
Are vpn clients getting a dns server address?
group-policy DCPDS_SOA attributes
dns-server none
techiegrl Tue, 07/29/2008 - 12:34
Yes, the vpn clients are getting through and getting the test banner, but for some reason when I add the DNS that we use for outside it does not work. THanks.
