Site-to-Site VPN Tunnel is Not Coming between 2 Routers
Answered Question
Jul 29th, 2008
Dear All,
I have 2 branch routers being configured for site-to-site VPN, but the tunnel is not coming!
I ran debug and I am attaching herwith the output for your kind review and recommendation. I am also attaching here the configs of the 2 branch routers.
Any idea on why the Site-to-site VPN is not coming up?
Haitham
You got it!
Only because you re-used the same crypto map for both the lan to lan and the vpn-client traffic.
this from the DOC CD
no-xauth
(Optional) Use this keyword if router-to-router IP Security (IPSec) is on the same crypto map as a Virtual Private Network (VPN)-client-to-Cisco-IOS IPSec. This keyword prevents the router from prompting the peer for extended authentication (Xauth) information (username and password).
Overall Rating: 5 (1 ratings)
haithamnofal Tue, 07/29/2008 - 22:29
Hi Joe,
Yes it worked perfectly...
So, what is the need for NO-XAUTH here, I have configured multiple site-to-site VPNs without using this keyword?!
Is it because I am configuring remote access VPN on the HQ router?
Haitham
Correct Answer
You got it!
no-xauth
