Devices in Questioned State and DFM3.03 not sending notifications
Jul 29th, 2008
I am currently running LMS3.01 with DFM 3.03 and all my devices are in Questioned State. The DFM is no longer sending Alerts and Alarms to Notification groups. I checked the Notification Groups and there were no devices in Devices Selector. My support maintenance is yet to be signed so I can't call TAC. Your help will be appreciated
frankzehrer Tue, 07/29/2008 - 23:58
  • Silver, 250 points or more
Hi Friend,
if you are using Windows have a look if .NET 2.0 SP1 is installed. If yes removed it and restart the server.
If this does not match have a try with the reset of the database passwords of DFM:
First you have to stop the processes
net stop crmdmgtd
cd to ..\CSCOpx\bin
Then issue the following cmd:
.\perl dbpasswd.pl dsn=dfmEpm npwd=
.\perl dbpasswd.pl dsn=dfmInv npwd=
.\perl dbpasswd.pl dsn=dfmFh npwd=
Hope that helps a bit.
Best regards,
Frank
Joe Clarke Wed, 07/30/2008 - 07:19
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
If you go to DFM > Device Management > Rediscover/Delete, what is the reason the devices are in a Questioned state?
dmamattah Wed, 07/30/2008 - 08:12
i did a database initialization and most of my devices are now in a Known state. But a have about 5 in Others and 10 in SNMP Timeout states
Joe Clarke Wed, 07/30/2008 - 08:15
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
SNMP Timeout is pretty self-explanatory. Make sure the SNMP credentials in DCR are correct for these devices, and increase DFM's SNMP timeout under DFM > Device Management > SNMP Config if necessary.
If you click on one of the devices under Others, what is the underlying reason it is Questioned?
