sumesh_un Wed, 07/30/2008 - 01:30
that was helpful but what I need to know is whether I can have content filtering,intrusion prevention,firewalling and VPN concentration on the same ASA box?
robertson.michael Wed, 07/30/2008 - 13:53
  • Silver, 250 points or more
The ASA only has a single slot for expansion cards (i.e. SSMs or 4-GE card). So, to answer your question specifically, you will not be able to use all of these modules on the same physical ASA.
Hope that helps.
-Mike
mherald Wed, 07/30/2008 - 21:46
As some persons have all ready mentioned, you aren't going to get all of that in one box.
You can get 3 and 4 in all ASA models.
You can get (1 OR 2) and 3 and 4 in 5510s, 5520s and 5540s.
1 and 2 is not availible in a 5505, 5550, 5580-20 or 5580-40.
Additionally, any time I have installed a AIP or CSC and you look at ALL possible traffic for either module, the ASA hasnt always responded so well. The CSC module had issues, specifically in redundant configurations.
Mike
