OSPF and the Process ID
Jul 30th, 2008
Hi all,
Just getting to grips with OSPF for my CCNA. I have a question which I'm sure most of you will be able to answer easily.
On an Area Border Router when configuring 'network 172.16.0.1 0.0.0.0 area 0 and network 192.168.0.1 0.0.0.0 area 1, can both lines be configured under the same OSPF process ID, ie 'router ospf 1'? Or when configuring 2 OSPF areas, does that router need 2 OSPF processes running?
Thanks all,
Garry
Overall Rating: 3 (2 ratings)
lee.reade Wed, 07/30/2008 - 01:18
  • Silver, 250 points or more
You just use the single ospf process id, and put all your network statements in there.
LR
ellendrew Wed, 07/30/2008 - 03:41
You may run multiple OSPF processes on a single router, but take note that it creates multiple database instances that add extra overhead to the router.
